Installation & update
Is NVIDIA GTX 1060 6GB working right?
Hello everyone!
I recently purchased this video card in the hope of getting high rendering speed. But there are suspicions that something is not working properly.
Please look at the windows task manager screenshots. Is the computational load distributed correctly? I honestly do not understand this, perhaps it should be so?
Just apparently I expected more ...
Thank!
The CineRender Engine uses only the CPU, it does not take advantage of the GPU.
There are various other rendering engines which use the GPU, but CineRender is not one of them.
Now it is clear!
I'll try to use other rendering engines.
Big thanks for answer!
