2014-05-04 07:34 AM
Reinstalling AC solved some problems that I had initially after migrating to this machine, but I'm beginning to wonder if I should just start with a clean install of the system on this iMac?Transferring data between computers with Apple's Migration Assistant
/!\ Warning: Transferring user data to another computer via Apple's Migration Assistant to another computer with a newer OS X version (i.e. Computer A running OSX Mountain Lion 10.8 to Computer B running OS X Mavericks 10.9) is not advised and may result in corruption of ArchiCAD and BIM Server software.
The recommendation is that you first back-up your project files and Teamwork data, then uninstall any GRAPHISOFT software from the original computer, perform the Operating System migration, then re-install GRAPHISOFT software on the new computer. Failing to do so may result in you having to fully re-install your operating system on the new computer and install all programs from scratch along with user data.
2014-05-04 03:37 PM
2014-05-04 08:44 PM
2014-05-05 02:40 AM
2014-05-05 02:50 AM
