Keypad changing in the middle of projects on Archicad 13
Has anyone experienced your keypad changing keys in the middle of a project? I go to type a command such as ctrl+shift+d and I find that the keys have changed and I have been unable to find a way to reverse it. This has been a huge problem for me and requires me to shut down Archicad and re-boot every time. Is there a way to fix it without closing down Archicad?
4 REPLIES 4
Are you changing your work environment by any chance? (hence maybe changing the keyboard shortcuts).
Or do you have another program running that is over-riding the shortcuts?
That is a good question Barry. To the best of my knowledge I haven't changed my work environment. It usually happens right in the middle of me typing in some command and as we all know we type commands so quickly and before we realize what happens we are miles past what we did that caused the problem. I do have other programs running such as Microsoft Word and our email program called Groupwise, but it wouldn't seem to me like this would make Archicad change keypads.
I just went through the shortcut list and I didn't see anything there that would change the keypad either. Admins, have you seen anything like this before?
David Maudlin
You can try going to Work Environment, select Shortcut Schemes, select the Stored Scheme you are using, and click the "Apply Scheme" button.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
