ā2004-12-23 02:40 PM
ā2004-12-23 07:38 PM
g.h.design wrote:Is 2D OpenGL on?
There is also a slight lag on 2d screen when I pan. If there is text in the window it scrolls much more slowly (hourglass at each press of the arrow key).
ā2004-12-24 02:15 PM
ā2004-12-24 02:29 PM
g.h.design wrote:Did you run the graphics card test from the Forum? Graphic card test, bottom left on the main page? I am also cursed by ATI both at home and at work, and found the results to be mixed, but definitely better without OpenGL in 2D.
Yes, I have OpenGL 2d on. I have tried it with it off and the results are mixed. The lag time for scrolling goes way up if there is any text on screen with OpenGL off. And the text looks pretty bad. I think it may help some what in the elevation window. Another thing is, that if I turn off the terrain meshes it speeds things up.
ā2004-12-24 03:03 PM
ā2004-12-24 06:26 PM
g.h.design wrote:This behavior doesn't make sense to me ... running on a very similar machine, but with the ATI 9700 Pro card. If anything, text would look bad with OpenGL (potentially polygonal edges and other issues). Running without 2D OpenGL, the text should always look reasonably good.
ā2004-12-27 02:15 PM
ā2004-12-27 07:14 PM
g.h.design wrote:Did you do the test?
mmm.... This morning it is working fine with the open gl off as per your screen shot.
ā2004-12-28 02:14 AM
