Learn more
nyangaujames1994
Language changing
Hello I have downloaded my archicad in a German language please how can i change it to english
3 Replies 3
nyangaujames1994
Can someone help me please
runxel
Hi @nyangaujames1994, the language is deeply embedded in the program. You can't change it.
To use Archicad in English you'll need to download the English version.
But depending on your license you may not be able to run it.
There is an INTernational version (it is English) that might run with you German Licence (that is probably what runxel is referring to).
You can download it here ...
https://graphisoft.com/resources-and-support/downloads?section=product&localization=INT&product=arch...
Give it a try to see if it works.
