Language problem, does not show "ā", "ē" ect. letter
Good day.
I have the problem with the schedule lists, whey do not allow to input or show letter in Latvian language with "ā" or "ē". They show the letters in view, but when i put them on the layout they change them to simple "a" or "e", it is done with all letter with "long signes" like "'ū,ī ect."
1 REPLY 1
Minh Nguyen
Hi Janis,
Thank you for reporting the issue here and I am sorry about the experience!
After testing with recent versions of ARCHICAD, I cannot replicate this issue. I'm wondering if you can specify which version and build number you are using right now for further investigation?
Thank you very much! Looking forward to hearing from you!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
