Installation & update
Installing or updating your app. Hardware/software requirements, OS specs.
Library Part Dialog Box Sizing
Is there any way to increase the width of the settings box under the parameters section? Many of the settings are often truncated so it is hard to know what you are actually trying to set. You can make the overall Settings window larger but that doesn't affect the parameters box.
2 REPLIES 2
TomWaltz
- Close the left-hand size or the settings window to close the "browser" portion. (the down-arrow in the upper middle of the menu).
- Resize your window so you can see the parameters you want.
- Re-open the browser side
- Open Work Environment and redefine your Palette Schemes so it stays this way,
Tom Waltz
__archiben
this last step doesn't work for me. those dialogues get saved with the app and not the WE profile . . . try doing a new and reset all and the re-applying your profile . . . if you're confident that is
~/archiben
b e n _ f r o s t
