Installation & update
Library Update Trouble
When attempting to install Library Hotfix #2 I get an error message saying it cannot access one or more files in Archicad. It worked seamlessly on three other Macs in the office. Suggestions?
4 REPLIES 4
jegomez
I have the same issue. I have no Idea what to do. Any help would be appreciated.
Thanks.
ArchiCAD 15 3267 USA FULL
Windows 7 Professional - 64-bit Operating System
Intel Xeon W3550, 8gb RAM, NVIDIA Quadro 600
Some ideas:
Did you modify the LCF file?
Did you remove any folders or files from the ArchiCAD library?
Porter Fuqua
I am getting a similar error on a Windows 7 64-bit machine. The update process wouldn't initialize because there was some access error. After I uninstalled and reinstalled Archicad 14 it took the latest hotfix.
However, I just tried to install the last library update and it give the same error that I got before.
It is not my workstation but we have 5 Windows machines with nearly identical software configurations that had no problems with the update.
iMac - 2.93GHz Core i7, 4GB, OSX 10.6.7
ArchiCAD 15
Greg Kmethy
Graphisoft Alumni
I have seen this happening when there were third-party libraries installed within the ArchiCAD Library folder. If any file or folder within the "ArchiCAD 14 Library" folder lacks "write" privileges, that could be causing this.
Gergely Kmethy
