Installation & update
Locked document error
Hi there
I have been trying to reslove this situation for sometime now. I have used all recommendations in this forum and others mentioned on the web, with no joy.
We are running a local shared window 10 pro network with one server and 4 workstations.
Files are constantly being backed up and synced through the "google drive" cloud service.
Randomly when saving to the server it requests that a "file save as" is performed because ... "This file name is in use by a locked document. Select another folder or use a different name" error message appears when trying to save over the current file.
Solutions I have tried/investigated to date include:
-deleting the .lck file. works initially then doesnt
-checking all the access privileges on the server machine, assigning full access read and write to the drive and all folders within. I must admit there maybe something that I may have missed here.
-turning off google drive syncing
-turning off antivirus software and windows firewalls on both the server and clients
Any help that someone could provide would be appreciated
Thanks
Bazza
AC23 NZE 3003
Wind 10 Pro version1909, OS Build 18363.720
i7-9800X
64GB ram
P4000 Nvidia Quadro
5 REPLIES 5
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Hi Bazza,
Thank you for sharing the issue and I am sorry about the experience!
After reading the description, my first thought is it has something to do with the Google Drive cloud syncing. I don't use any cloud service for backing up my project plan file, so I don't know whether there is any mechanism under it. But we had some reports about issue with saving plan file that is syncing to the cloud. Usually, the syncing process might block the writing process. Although I can see that you have disabled Google Drive, I'm wondering what will happen if you work on a new file, still save it to the server but without having it back up to the cloud?
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Thanks Minh for your advice.
Previoulsy I have only paused the Goolge backup facility. I have stopped this entirely and it seems to have alleviated the problem (as far as I can see presently).
I have now set a schedule through Windows Task Manager to run the backups outside office hours. I will monitor and report back with the outcome
Thanks again
Bazza
This post has been moved as it is not really a discussion about Archicad so does not really belong in "Archicad+".
I would say it is a problem with the cloud sync.
My company does not use a cloud sync but it does have a live sync with other servers in the company.
I have noticed if I save a file directly to a server and then hit save again straight away, it wants to do a save as.
If I leave for just 10 or 20 seconds I can save again with no problem.
I think as Minh has suggested, during the sync process, the file becomes locked.
As soon as the syncing is finished, it should be released again.
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Hi Bazza,
Glad I could help! If the issue still happens, let me know so that we can test something out (but hopefully it is solved now by turning off cloud syncing!)
Have a nice day, and stay safe!
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
David Bearss
Ah! same issues for me too.I use both google drive and one drive, and google drive seems to be the culprit however waiting 20 seconds does not seem to resolve. No shared servers or nothing fancy but would be interested if this is a challenge that other users are experiencing. For now I simply add a date or time stamp to the file name and delete older versions at some point during a directory sweep up.
David Bearss
Archicad 18/Windows 11
Alienware 17 R5
i7 2.4 GHz / 16 GB ram
