Logitech Setpoint driver conflict with ArchiCad
I know this subject has been discussed in the past however it is a new problem for me. I have a MX Revolution mouse and with the Setpoint 652 driver software installed I get problems with the mouse operation in ArchiCad. I worked around this by uninstalling Setpoint and just using the MS driver which works OK.
I now have Windows 8 and have starting using the t650 touchpad which works well except that it requires Setpoint to operate. So the problem re-appears.
Does anyone have any new information about this issue?
10 Replies 10
Eduardo Rolon
No problem. If I remember correctly there might be some sensitivity settings you can play around with.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
