Klarka
Mac shortcuts
Hey, I was wondering, how do you recreate shortcut (for example) ctrl+M+ctrl? When I want to activate the mirror image, plus create a copy on the other side? It seems to work on windows, but not on mac. Cmd+M works, but the second (ctrl) cmd, that would activate the copy (the small + sign next to cursor) doesn't activate nothing. Any recommendations? Thank you ^^!
MacOS, Archicad v. 27
1 Solution
David Maudlin
Klarka:
There is the Mirror a Copy command (default shortcut is Command + K). Go to Work Environment > Shortcut Schemes > Keyboard Shortcuts to verify or change its keyboard shortcut.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Go to post
4 Replies 4
DGSketcher
Legend
Select object(s), click cmd+M (or other variant) and then independently click on the ALT (option) key.
When dragging a copy you can also place multiples by hitting cmd+Alt together.
David Maudlin
Klarka:
Klarka
Right, thank you! 🙂
David Maudlin
Klarka:
Good to know that worked, thanks for adding your signature.
