‎2023-10-20 06:33 PM
Hey, I was wondering, how do you recreate shortcut (for example) ctrl+M+ctrl? When I want to activate the mirror image, plus create a copy on the other side? It seems to work on windows, but not on mac. Cmd+M works, but the second (ctrl) cmd, that would activate the copy (the small + sign next to cursor) doesn't activate nothing. Any recommendations? Thank you ^^!
Solved! Go to Solution.
‎2023-10-21 03:23 PM
There is the Mirror a Copy command (default shortcut is Command + K). Go to Work Environment > Shortcut Schemes > Keyboard Shortcuts to verify or change its keyboard shortcut.
David
‎2023-10-20 11:32 PM
Select object(s), click cmd+M (or other variant) and then independently click on the ALT (option) key.
When dragging a copy you can also place multiples by hitting cmd+Alt together.
David
‎2023-10-22 12:41 PM
Right, thank you! 🙂
‎2023-10-22 02:57 PM
Good to know that worked, thanks for adding your signature.
David
