MacOS place of .plist
runxel
Legend
While Windows has the registry, MacOS uses those weird .plists. You can edit them to get some "hidden" behavior of Archicad.
There is an old knowledgebase article, but the information in there is not up to date.
So, long story short: WHERE has the .plist gone?
In other news: The arc resolution of shells in AC 27 is still shite and still can not be adjusted. Sigh.
Lucas Becker | AC 27 on Mac | Graphisoft Insider Panelist | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text | My List of AC shortcomings & bugs | I Will Piledrive You If You Mention AI Again |
2 ACCEPTED SOLUTIONS
Hi Luc,
I found mine for AC27 ARM here:
~/Library/Preferences/com.graphisoft.AC-ARM\ 27.0.0\ INT\ RC1.plist
Hey @BerndSchwarzenbacher, thanks, I now realized why I couldn't find it.
Sorry @MinhNguyen: The info there IS NOT true!
The correct location is the one Bernd posted: "~/Library/Preferences/" – note the tilde in front! (= user directory).
It is not in the similar sounding system location "/Library/Preferences/" which also exists.
It is true that editing a .plist file is a hassle on its own. However I found this neat VSCode extension that works very well. It will present the .plist in XML format where you can do seemless editing.
4 REPLIES 4
MinhNguyen
Other than trying to find its location, I assume what you want is to actually edit the PLIST?
There's a guide for that (and I realize you linked the same article as well): https://community.graphisoft.com/t5/Installation-update/Altering-ARCHICAD-behavior-Registry-or-Prefe...
and it was updated quite recently, so the information is valid
P/s: I can try to find them tonight, however if my memory serves me right, without a Plist editor it's quite difficult to edit it anyway
BIM Manager
DKO Architecture - HCMC
Hi Luc,
hmm, you're absolutely right. I'm pretty sure the original version got that ~ character, as later down the article the full link was mentioned, which is <current user>/Library/Preferences
BIM Manager
