2008-06-18 10:31 PM
2008-06-21 08:25 PM
Brock wrote:Could it be that you have different dimensioning sets in different views? Please check if they are the same, and whether the d/w centerline dimensioning is on in one of them and off in the another.
When using view map in the organizer, I have had a problem (2 projects now w/ version 10) with my dimensions changing @ the windows and doors. I dim. to the centerline of the windows and doors (from archicad 10 library) and when I jump between views my dims now change to the edges. Now, if I jump around again in my views and go back to that same view the dims will go back to the centerline. It will plot whatever the drawing looked like the last time I viewed it. Someone make this madness stop! Help?
2008-06-26 06:02 PM
