Installation & update
Missing Design Options Palette
Stephania
Hi! I've just installed the new ArchiCAD 27 and I cannot find my Design Options Palette, not under Window, not under Document. I even installed the update for the 27 version. Help please!
ā€ƒ
Hi @Stephania ,
Welcome to the community, but please try searching the forums before you post a question.
A simple search for "Design options palette" would reveal this post.
https://community.graphisoft.com/t5/Installation-update/Design-Options-Palette/m-p/576805
I believe that will be your solution too.
If not, let us know.
Hi @Stephania ,
Stephania
That was it. Thanks a lot!
