Installation & update
Network license
I am new to ArchiCAD. We have an hardware license installed on the network. Other systems on the network are working fine. ArchiCAD is not recognising the hardware license when I run it on my system though my system is on the same network and workgroup. I am able to access the system that has the hardware key.
Any ideas on what should be done?
5 REPLIES 5
Hi there,
I am new to ArchiCAD. We have an hardware license installed on the network. Other systems on the network are working fine. ArchiCAD is not recognising the hardware license ...
could it be that you installed the AC net license program WHILE having the AC key attached to the computer?
If so, remove key and uninstall program.
Reinstall software again, restart and THEN plug in the AC key ...
The key was attached after the software was installed. AC is working fine on all the other systems. It is only on my system that I am able to work on it some days. On some days AC runs in demo mode because it cannot detect the key.
Djordje
Maybe all the licenses are taken?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
We have license for 20 users and our team is only 10 as of now.
Ben Odonnell
In the network tab of the WIBU key applet, you will find it in your control panel, type in the ip address of the server machine and take add.
Apply the setting and then try to start up ArchiCAD again.
HTH.
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
