New Fonts
Does anyone know how I add a new font to Archicads font list, I have added it to the fonts folder in windows but it has not shown up in archicad. for photoshop adobe has its own fonts folder in the program file section of photoshop but i cant find a similar one for archicad.
can anyone help?
4 Replies 4
Djordje
can anyone help?
ArchiCAD is using system fonts.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
That doesn't really help me,
i am not sure what you mean
where do i put the font in order for it to selectable
in archicad?
vistasp
Archicad doesn't have a separate fonts folder but, as Djordje says, uses what's available in the windows\fonts\ folder. You may have to restart the application after installing fonts for them to be visible to you.
Note that some GDL objects - depending on how they are programmed - will only use a limited number of fonts regardless of what you have available on your system.
Putting your OS and AC versions into your signature will usually give you more accurate answers.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
We work Archicad 12 rus put Georgian font, but Archicad does not read, can someone tells how to fix the problem WIND XP/ SP-3 rus , put the font so as pictured here posmatrim result
