New Intel Minis
TomWaltz
The Intel Mac Mini's just hit.... Dual Processor machine for $799.... not bad!
Tom Waltz
6 REPLIES 6
unfortunately the integrated graphics card that it has, might not make it the best machine for Archicad 10.
Thomas Holm
We use a G4 mini as a workstation (with a 21.3" Samsung flatscreen). Works fine with maxed out RAM, but isn't very fast with rendering, of course. Except for OpenGL, the processor is the most important speed factor in Archicad. A Dual will speed up Lightworks and Artlantis, and simultaneous use of other applications as well. When the Universal Archicad comes, it should run much faster on the new Mini.
The Radon9200 graphics card in the G4miniis fast enough for Archicad 9's modest use of OpenGL in 3D navigation anyway. And if you look at Macfixit's coverage, the new integrated graphics should at least not be significantly slower than the old mini:
http://www.macfixit.com/article.php?story=20060228103152918
As usual, I think to max out RAM memory is the most important issue.
TomWaltz
I just have this dream of an all-Mac Mini render farm. You could fit dozens and dozens of machines in a small room....
Tom Waltz
Eduardo Rolon
Does your dream look like this?
____
image from:
www.macminicolo.net/
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
TomWaltz
Something like that. I was picturing something with a cool fractal-pattern mounting though, not a boring rectangular grid.
Tom Waltz
Thomas Holm
Maybe you won't need all of them.
http://www.macintouch.com/index.shtml#tip.2006.03.01.solo
http://www.macintouch.com/specialreports/perfpack02/
