No Project Recovery Window when launching new instance Archicad on Mac
K_Bajorinaite
Beginner
Hello i'am using Archicad 24 on MAC, when I launch Archicad new instance File>New> launch new instance, the recovery file window doesn't pop up. To some colleagues it's the same and to others there is no recovery window as well, the only option is to close Archicad completely and relaunch to get the main window with recovery files. I wonder if this is a bug or maybe could have to do something with work environment, at this point I don't know anymore.
5 REPLIES 5
@K_Bajorinaite wrote:
.... the only option is to close Archicad completely and relaunch to get the main window with recovery files.
That is the way Archicad works.
You have to launch a new session of Archicad, not just open a new file, for the auto recovery to kick in.
I think you may even have to close all other running Archicad sessions first - but I am not 100% sure on that.
I do launch new instance, but on some computers we get this recovery window ( by doing the exact same steps ) and on some like mine this window doesn't pop up.
my experience says you're right Barry. If one AC session crashes, you have to quit all others before re-launching. It's not a 100% guarantee that you'll get a recovery file option, but it's the surest bet.
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 29 / AC29.0.2 USA
Rhino 8.27 Mac
MacOS Tahoe 26.2
K_Bajorinaite
Beginner
I am sorry I made a mistake while typing the topic, what I meant was this window that pops up, not recovery files themselves.
As I mentioned, make sure all running copies of Archicad are shut down before restarting.
I am not familiar with Macs, but in Windows we have a task manager where we can close running applications.
Also check your Work Environment to see where your temporary files are being saved.
If you go to that location, you should find the auto recovery folders ("Archicad_number") - do you have access?
They will delete automatically when Archicad is shut down properly and should remain if Archicad crashes or is force to quit.
Again this is Windows, not Mac.
