Open GL 3d window
Guys I need help!
I got a file a colleague had earlier work on and am trying to continue building the 3D model, the model is visible in 3D window (Open GL) only at certain angles and gradually disappears from view when I rotate in certain directions. Its behaving as if there is a plane beyond which the elements can't show. Please help!
2 Replies 2
Sounds like it may be related to this issue:
http://www.archicadwiki.com/Bugs/Model%20cut%20in%203D?highlight=%28CategoryOpenGl%29
Thanks a lot.
That was the problem, and FYO, I had gone past it by copying the 3D elements and pasting in a new archicad file.
