OpenGL incorrect display with nVidia Quadro FX 580
Finishes are not showing up correctly on different surfaces of construction elements in Open GL. See attachement. The walls on the left have ArchiCAD's 6" Siding with the "Lines H Gradient Alpha.png" texture on all surfaces. When I change any other surface of the wall the color of the wall the surface with the siding takes on the color of the other surface. The walls on the right have red on the inside & top & bottom faces and the red shows thru the siding. All the other elements have similar problems. The roofing on the right have blue on the top of the roof a white on the sides, but it shows all white. The door has different colors on all elements, but the door and casing are all blue. The mesh and slab are also not showing correctly. Don't know if this a Video Card Problem but I just upgraded to a new computer with a nVidia Quadro FX 580 Video Card, with the latest driver. My partner on his MAC doesn't have the problem. My computer is:
Intel i7-2600K, 3.40 GHz, 8MB cache
Mitel DH67BL Motherboard
8 GB Ram
1 TB hard Drive
Windows 7 Pro (64bit)
0 Replies 0
