Blue
Pan function Contour Unimouse
I guess this is a long shot, but I´ll give it a go.
I use Mac (M1) Arch 28, it is updated, and a Contour Unimmouse (https://contourdesign.no/collections/one-handed-mice) and have been quite happy with it.
Although - when I tried to download the driver to the mouse, the pan-function in Archicad stoped working. It pans back and forth, but will not rotate around in the view. ( I use pressing down the roller-wheel as preferred pan-button)
I deleted the driver, and it was fine again.
Today I updated my Mac to Sequoia 15.4. And the pan-rotating stopped working.
I tried to download the driver again, but with no luck.
Anyone with similar problems..? Solution options?
Or do I have to start looking for another mouse..?
I have also contacted contour support, but I have small hopes.
1 Solution
Blue
Accept that now the right-click does not work..🙄
Go to post
Blue
So, I deleted the driver again, restarted the Mac - and the pan works. Puh 🙂 Problem solved.
Blue
