2004-09-17 10:27 AM
2004-09-17 10:43 AM
2004-09-19 07:58 AM
Aussie wrote:Right click on the layout you want to import the elevation in, choose Import, choose the PLN file, choose the appropriate view in it, and check Place on current layout - or create a new one, as the case may be. You can add and delete as much as needed.
Can't seem to find option anywhere, only import [filename].pln, which I assume I will need to rearrange everything again??
2004-09-20 04:21 AM
