2009-02-20 08:08 PM
2009-02-20 08:28 PM
2009-02-20 09:39 PM
Steven wrote:Actually, the solution is for Graphisoft to produce library parts that work - then nobody will see this and other errors. The problem is that many Graphisoft library parts do not do sufficient error-checking and consistency-checking on their parameters, allowing the entry of values (as you've seen in the past) that cause the part to bomb out.
Doing a little research, it seems that there is not definite way to figure out what is the problem, just through the process of elimination. There should be a way to jump to the error or the element that is causing the error. This would save many people a lot of time...
2009-02-20 09:44 PM
2009-02-21 05:35 AM
Steven wrote:You are absolutely right! Even half-by-half elimination process takes 5-10 min, and it can take more, if there are more than one spoiled element...
2009-02-22 07:48 PM
