Installation & update
Possible problem - dimensions don't appear (AC21)
Mats_Knutsson
Mentor
several users have had problems in different projects over time. The problem is the dimensions don't appear when "hammered"...a possible key to the problem is if int the Publisher a shortcut that is set to publish ifc is "active". It looks for translators on our server. If we change to the pdf Publisher set the dimensions show. Also this little trich changing from an "ifc shortcut" to a pdf-shortcut makes Archicad run smoother. Kind of whimsical problem but confirmed from many of our power users.
Anyone else perhaps?
AC 25 SWE Full
1 REPLY 1
Erwin Edel
Any difference using the 'ok' button from the control box palette?
We had problems with dimension 'confirming' ages ago and all started using that instead. Been doing that so long, I don't know any better anymore.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
