Installation & update
Print 2D Document windows cut off
AEismann
Hi all,
Does anyone know how to fix the 'Print 2D Document' being displayed cut off ? (the low right side is missing).
Thanks in advance
AC23 NED 7000 | AC24 NED 5000
Win10 | i9-9900k | 32GB | RTX 2080 Ti
By any chance do you have a hi-res monitor and you have scaled the display size in the Windows settings?
If so try setting it back to 100%.
If you do set it back, you may need to restart your machine if restarting Archibald does not work.
4 REPLIES 4
AEismann
Barry, thanks for the quick reply, I will try it. crazy that i have to restart my computer to do that, I get some
other weird stuff with other apps (3dsmax) to be honest, dont know who to blame anymore... i didnt imagine 2020 with so many bugs in the basic interface of windows but here we are.
I don’t know if you will have to restart.
But it is always a good idea to, especially if nothing seems to happen when you change a setting.
AEismann
scaling to 100% and then restarting fixed my problem.
