Problem with Goodies Add-on in AC26 INT
BIM Architects
Hi there
I have installed Goodies_Suite-26-INT-3000-1.0, but accessories and other goodies  are not displayed in menubar the "Design/Design Extras" !!!
However, in installed folder in Program Files  I have Accessories Library 26  (please have a look screenshot)
Than I have installed Updates for Archicad 4019 but its doesn't help.
I have loaded Accessories Library 26 (please have a look screenshot)
Has anyone had such a problem?
What should I do?
Best Regads
14 REPLIES 14
Yes, this works as long as you have the hotfix 4019 and follow the procedure that @Barry Kelly stated. 😎
In the end what is your Objective?
ArchiCAD 9 onwards
last time they didn't have the hotfix update now they got it already so you can do this method. 😎
ArchiCAD 9 onwards
So as I understand  this problem appeared in the AC26 version, right?
@BIM Architects wrote:
So as I understand that this problem appeared in the AC26 version, right?
Correct.
And supposedly it will be fixed in the future.
Vasilije Djurovic
After few hours of frustration. I simply just go to Options>Add-On Manager,
then deselect all add-ons and press Ok > Save Changer and Reload Project.
When program restart,
Select all add-ons and press Ok > Save Changer and Reload Project.
Program will restart again and your goodies will be uploaded.
Vasilije Đurović
