Installation & update
Problem with Vista Home Premium 64xbit
I have Intel Core 2 quad 2,5GHz, Ati 4870 512MB, 4GB RAM and Vista Home Premium 64xbit
Everthing is fine but when I switch to 3D the AC12 get froze and I have to shut down AC. I dont know what to do with it....Help please
P.S. I'm not good englisch speaker because I'm Czech, sory. I've hope you will understand it.
8 REPLIES 8
Try to install the latest drivers for the graphics card and see if that helps.
I did it but AC12 stil not working.... I can switch to 3D and draw something but when I can move screen or rotate then it froze...
laszlonagy: you have vista 32 bit or 64bit? I think there is the problem... But how can I fix this?
Nice.... I found result....in scheme I change Open GL 3D to internal 3D engine and it works......thanks for your help šŸ˜‰
Yes, this is because the Internal Engine does not use the hardware acceleration available in OpenGL.
But you will also notice that it is much slower than OpenGL so I think you will still want to get this problem solved so you can use the OpenGL Engine.
Edit: By the way:i have Vista 32-bit.
Hi!
I'm having great trouble trying to work with ArchiCad 12 in Vista.
I have Vista Home Premium, and everytime I try to save what I've done in AC, it shuts down... What can I do about it?
Thanks!
henrypootel
@Cjman - Try turning off Aero. Just change your windows theme to Vista basic or Standard.
Josh Osborne - Central Innovation
HP Zbook Studio G4 - Windows 10 Pro, Intel i7 7820HQ, 32Gb RAM, Quadro M1200
to henrypootel: Aero is turning off automaticaly when I open AC 12.....
What is different between bussines and home premium? And why it is ok on 32bit home premium but on 64bit no?
oh, i forget one thing, I start AC12 in mode compatible with windows XP SP2.......cause if i start it normal it write that i have not instaled QuickTime 7 or newer version...but I have the latest version of it......I did not find solution that I started AC with mode......Do you know some other solution?
