I have Intel Core 2 quad 2,5GHz, Ati 4870 512MB, 4GB RAM and Vista Home Premium 64xbit
Everthing is fine but when I switch to 3D the AC12 get froze and I have to shut down AC. I dont know what to do with it....Help please
P.S. I'm not good englisch speaker because I'm Czech, sory. I've hope you will understand it.
Yes, this is because the Internal Engine does not use the hardware acceleration available in OpenGL.
But you will also notice that it is much slower than OpenGL so I think you will still want to get this problem solved so you can use the OpenGL Engine.
Edit: By the way:i have Vista 32-bit.
Loving Archicad since 1995 - Find Archicad Tips at x.com/laszlonagy AMD Ryzen9 5900X CPU, 64 GB RAM 3600 MHz, Nvidia GTX 1060 6GB, 500 GB NVMe SSD 2x28" (2560x1440), Windows 10 PRO ENG, Ac20-Ac29
Hi!
I'm having great trouble trying to work with ArchiCad 12 in Vista.
I have Vista Home Premium, and everytime I try to save what I've done in AC, it shuts down... What can I do about it?
oh, i forget one thing, I start AC12 in mode compatible with windows XP SP2.......cause if i start it normal it write that i have not instaled QuickTime 7 or newer version...but I have the latest version of it......I did not find solution that I started AC with mode......Do you know some other solution?
