2008-01-23 01:02 AM
2008-02-04 01:11 AM
2008-02-04 10:34 PM
drh64 wrote:If that was the scan result for your hard drive, then I'm afraid you've got yet another bad drive. I'd recommend showing those results to Apple and get them to replace the drive again. Check if they can transfer the data for you too.
Results from a TechTool Scan overnight:
Surface Scan
Failed - 1 errors
The Surface Scan test will scan the disk for bad blocks.
Media defects cause this test to fail. You should consider backing up the device, reformatting the media, replacing the data, and then testing again.
Does this mean I should backup, reformat and reinstall EVERYTHING!!????
2008-02-09 04:01 AM
owen wrote:Now i have.Ralph wrote:... Haven't seen this sort of thing on any of the 40 odd Mac Pros + G5s in the office either
There certainly isn't a problem running iTunes (and much more) in conjunction with ArchiCAD - I (and many others) do that all the time.
2008-02-09 04:09 AM
owen wrote:Bummer. My machine, configured as above, should be arriving early next week.
We have just started receiving the new 8-Core Mac Pros with the standard ATI Radeon HD 2600 card (pretty much the same card as the iMac has). Every single one of them (5 so far i think) is displaying this behaviour.
2008-02-09 04:14 AM
2008-02-09 05:50 AM
2008-02-09 07:45 PM
2008-02-09 09:07 PM
2008-02-11 02:23 AM
2008-02-11 03:00 AM
owen wrote:So far, and it has been a short time, I have had no issues here with the ATI 2600 (2 - 23" displays), and so much quieter than the ATI X800, also 256 mg... which I had no problems with either on the G5.
The fact that this problem is heat related is understandable (not excusable) with the enclosure of the iMac but a real worry given the Mac Pros are certainly not lacking for airflow.
