Installation & update
Problems with extracting .lcf file
I originaly posted this in the ACE Library topic but now that I tried some new stuff I think its worth asking again.
I'm having issues with extracting a library in the LCF format to get all the parts in folders so I can fiddle with it a bit. I tried using the "extract container" command but in the target directory I only get 4-5 folders out of the supposed 35 or so.
I have the exact same result with saving as PLA and extracting to a folder upon opening the file, only a couple folders get there.
Do I need to close any AC open with that library active before I extratc? I tough that the PLA method wouldnt need to.
Anyone have an idea about this, im a bit desperate.
Thanks in advance, and sorry for sorta doubleposting.
13 REPLIES 13
Andy Thomson
It's a mac/pc thing. You ought to download the PC version. XP/Windoze machines can't deal with some of the 'funny european' characters and decide to go on strike when they see them, which is why extraction aborts.
Andy Thomson, M.Arch, OAA, MRAIC
Director
Thomson Architecture, Inc.
Instructor/Lecturer, Toronto Metropolitan University Faculty of Engineering & Architectural Science
AC26/iMacPro/MPB Silicon M2Pro
I have never had any luck trying to extract the ACE library.
And I do have the PC version.
This is all that extracts - just tried again in version 13 as well.
Compared to what there should be.
vistasp
The same happens here and presumably on all PCs. I would love to have a zipped (instead of lcf) version of the ACE library so that I could choose what object I want to load. Of course that would mean having to deal with macro dependencies... 😉
Any chance of a zipped version Andy?
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
Andy Thomson
It's not the lcf that causes the problem afaik - it's the umlauts etc. in the actual objects that cause the unpacking to fail - I tried lcf and zipped versions when I created this. I had to manually rewrite every offensive character on a mac when I made the pc version - and my pc version loaded fine - unfortunately - I don't have any time to dedicate to this project right now - but I would suggest working between a mac and a pc to discover this current problem - are you sure it was the pc version? The torrents have been re-seeded hundreds of times by others...
A
Director
When you extract it, you might want to choose a folder high in the root. So don't choose some folder in 'my documents' but in 'c:\'
Hope this helps.
vistasp
I'm certain it was the PC version Andy but will redownload tonight just in case. Whether I succeed in extracting the entire lcf or not, I just want to say many many thanks to you guys for having created this library in the first place.
Masterscript, I'll give your suggestion a try first - might save me some precious bandwidth!
= v i s t a s p =
bT Square Peg
vistasp
Nope. Didn't work.
Masterscript, the result of extraction is exactly as before regardless of whether it's to a root directory or not.
Andy, I tried with a fresh download of the PC version but no dice.
Giving up...
= v i s t a s p =
bT Square Peg
Erika Epstein
Could someone point me to the download for the international version?
Thanks
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
