Program crashes going from ArchiCAD to Plotmaker
Looking for a little help... I am having problems transferring files from ArchiCAD to plotmaker. Whenever I try to import an ArchiCAD file into plotmaker (or update a plotmaker pmk file) the Bug Reporter pops up and prevents this file transfer. One error I recieve is as follows: Error while reading file: site plan.pmk (256: File is not found, connection failed). Anyone have a solution for this?
Thanks,
Mike
6 Replies 6
Ben Odonnell
Mike,
Which version of ArchiCAD are you using?
Cheers.
Ben
Ben O'Donnell
Im using version 8.1 v2... forgot to mention that.
Thanks Mike
Thornewill wrote:
Looking for a little help... I am having problems transferring files from ArchiCAD to plotmaker. Whenever I try to import an ArchiCAD file into plotmaker (or update a plotmaker pmk file)...... One error I recieve is as follows: Error while reading file: site plan.pmk (256: File is not found, connection failed). Anyone have a solution for this?
I'm currently having exactly the same problem and never have before. No upgrades, system/ network changes and no-one else in the office is having the same problem. What's going on? Anyone? Please????
Djordje
Permissions?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
I still haven't fixed the problem with my computer... have you had any luck how to?
I've no idea what's going on , but the problem for me has disappeared. I don't know if it's networking, server problems or as you say Djorde, permissions, which somwehow now have changed. I can't be sure if someone in the office has changed some of these things in the course of the last week.
