Installation & update
Program crashes when in Open GL mode
The program shuts down. Open GL seems to be the problem. I tried using my older computer and had similar problems when I switched from the Internal engine to Open GL. I have dual monitor setups on both computers. My current setup is:
Processor: Quadro FX 1400
IRQ: 16
BIOS: 5.41.02.34.11
Adapter information
Bus: PCI Express x16
Memory: 128 MB
System information:
System Processor: Intel Xeon CPU 3.00 GHz
Direct X version: Direct X 9.0 or better
Any help would be appreciated.
1 REPLY 1
Djordje
What is the 3D window size?
It might be that there is not enough video card memory to run two monitors at a hig resolution, and OpenGL 3D window in one of them on top?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
