Projects from AC10 in AC12
Hi!
I'm currently working in Archicad 12 but I have many projects desinged in Archicad 10 and when I'm opening them in Archicad 12 I don't have windows and other objects are missing too. AC10 was international version and my AC12 is the same version too. How can I import my older projects to AC12 to see windows and doors? They are standard objects from archicad library....is there some migration solution? Thanks for help!
1 Reply 1
Did you make sure that Library Manager in 12 for those projects was loading the AC 10 library (or whatever libraries were originally used in the project)?
If for some reason that does not work, save a PLA of the project from 10 and open the PLA in 12.
