!Restored: ArchiCAD 10 installation issue - disk space
I'm trying to install v10 (student) in order to get a feel for the program. However, it gives me an install error: It claims I do not have enough disk space and need to clear off 331.95mb to complete the install.
I have 64.5 Gb free on the install drive...any suggestions?
6 Replies 6
You need to make the space. Perhaps you can write some older stuff to CD/DVD and get it off your hard drive. Pictures and music can take up quite a bit of room. Alternatively you can buy another hard drive or upgrade the one you have. What I usually do is buy a larger drive and an external enclosure, upgrade my internal drive, and put the old one in the enclosure as a backup or portable.
edit:
Oops! My mistake, I read to quickly and was thinking 64MB not GB.
Could it be a permissions problem?
David Pacifico
64 Gig should be enough space ':wink:'
Perhaps it is trying to install onto a smaller partition?
David Pacifico, RA
AC27 iMac i9, 32 gig Ram, 8 gig video Ram
Good suggestions, except I am running as admnstrator, so permissions are not the issue (in fact, this is coming at the tail end of a complete system reinstallation), and there is only one partition on the drive.
BTW. win XP Pro SP2 (completely patched), P4 3.2, 1 Gig ram, 75 gig SATA drive ...
...as is the case many times, I can;t explain this:
I decided to try it one more time, as if the previous 6 attempts did not count.
This time it installed flawlessly.
Go figure.
Thanks for your help & suggestions.
David Pacifico
Your system must of just been tired from the reinstallation.
David Pacifico, RA
lol
I don't know about my machine, but I sure am! 😉
