!Restored: I NEED HELP!!!
hi, I've got the ArchiCAD International 9.0, but when I've finisher installing it, I can't load it because of an error which says that I don't have the GSroot.dll file. can someone get in contact with me and send it to me? please, I gotta finish some work and I really need it... this is my mail, if someone can send me tha file I'd really thank him
[email protected]
THANKS
16 Replies 16
Ben Odonnell
Just backing up Woodys statement here, this is some thing that does work every time.
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
Djordje
... and please DO NOT post in ArchiCAD+ ...
Installation/New user - the forum defines itself!
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Well, I'm a programmer, so sometimes I find a way to enter the file which contains all those .DLL files... but in this case I couldn't.
I logged on as the Administrator, but even if I reinstall the ArchiCAD again, it will give me the same error. The problem is that the disc is broken somewhere so at 64% it stops installing... but, rarely, it doesn't say: "the installation have had a problem and had to end". It stops there as if it had already installed. I guess that if I get those files (which are not so many) it has to work. So I've an idea. Someone with ArchiCAD already working give his MSN so I can chat with him and get the files through there.
If it doesn't bother anyone...
Thanks Again
Ben Odonnell
I don't understand why you just don't get in contact with your reseller?
They will gladly send you out a new CD free of charge. Simple really.
Unless you are using an illegitimate version of ArchiCAD and don't have a reseller to contact!
Ben
Ben O'Donnell
That's it. Actually I'm using a copy. I didn't have enough money to buy the original. But, nowadays, it is normal. Anyway, I think if i get those files I solve the problem.
Thanks for your answer
Quite an irony as a programmer you are using a copy. Who compensates you for yor programming work?
I certainly hope you won't get too much sympathy here from people who worked hard to pay for their copies of ArchiCAD.
woodster
