!Restored: I NEED HELP!!!
hi, I've got the ArchiCAD International 9.0, but when I've finisher installing it, I can't load it because of an error which says that I don't have the GSroot.dll file. can someone get in contact with me and send it to me? please, I gotta finish some work and I really need it... this is my mail, if someone can send me tha file I'd really thank him
chatochato82@hotmail.com
THANKS
16 REPLIES 16
Ben Odonnell
Just backing up Woodys statement here, this is some thing that does work every time.
Cheers.
Ben
Ben O'Donnell
Djordje
... and please DO NOT post in ArchiCAD+ ...
Installation/New user - the forum defines itself!
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Well, I'm a programmer, so sometimes I find a way to enter the file which contains all those .DLL files... but in this case I couldn't.
I logged on as the Administrator, but even if I reinstall the ArchiCAD again, it will give me the same error. The problem is that the disc is broken somewhere so at 64% it stops installing... but, rarely, it doesn't say: "the installation have had a problem and had to end". It stops there as if it had already installed. I guess that if I get those files (which are not so many) it has to work. So I've an idea. Someone with ArchiCAD already working give his MSN so I can chat with him and get the files through there.
If it doesn't bother anyone...
Thanks Again
Ben Odonnell
I don't understand why you just don't get in contact with your reseller?
They will gladly send you out a new CD free of charge. Simple really.
Unless you are using an illegitimate version of ArchiCAD and don't have a reseller to contact!
Ben
Ben O'Donnell
That's it. Actually I'm using a copy. I didn't have enough money to buy the original. But, nowadays, it is normal. Anyway, I think if i get those files I solve the problem.
Thanks for your answer
Quite an irony as a programmer you are using a copy. Who compensates you for yor programming work?
I certainly hope you won't get too much sympathy here from people who worked hard to pay for their copies of ArchiCAD.
woodster
