ArchiCAD freezes
Hello,
My coworkers have been having problems with freezing and slowness in ArchiCAD but not in other programs (including PlotMaker). Their computers are fairly new (one is 6 months old the other 2 yrs), running on Windows XP. We are using peer to peer sharing network where my computer serves as the server. I haven't run into this problem yet, I have a new, more powerful computer, also running on Win XP.
Problem:
1. After ArchiCAD starts up (all libraries loaded), all operations are inhibited, except the mouse movement and zoom. So basically you cannot select an object, a tool, or anything except moving the mouse cursor and scrolling its wheel to zoom. This can last up to 1 minute and it occurs more often when opening more than 1 Archicad project.
2. After staying in one program for a long time (~0.5 - 1 hr.) then switching between programs would slow down, especially with 2 or more Archicad projects open at the same time.
Tried:
1. Archicad runs faster when opening the project from the computer’s own C drive.
2. Without opening Archicad when computer starts up, opening a network folder is very slow
We’ve tested several possibilities but still don’t know if this is a network problem or because Archicad has a bug. One person already installed the new update and when it didn’t solve the problem he reinstalled A 9.0. However, the problem still persists.
One other point: our network cables are 25’ to 50’ long when each of our stations are only less than 2 feet from the ports. So we end up coiling the extra cables up. Would this deplete or slow down any information that we share?
Djordje
What are the specs?
If you are peer to peer, you cannot have a server - maybe the protection key is on your computer?
This all sounds like not enough horsepower, OR a slow network that chokes on largish files.
Speeds of the disks and RAM play huge roles - if all of you don't have at least 1Gb each, it will be slow.
Check Task Manager and see what happens ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
