Aaron Bourgoin
Restoring the "Open File - What Do You Want to Do" dialog
Is there a setting to restore the Open File StartUp dialog box? I've dialled this by accident and now have to start ArchiCAD and let it open a new file before I can access this dialog.
I scoured the preferences for a button, but haven't found anything that is relevant. Thanks!
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 29 / AC29.2.1 USA
Rhino 8.35 Mac
MacOS Tahoe 26.6.2
4 Replies 4
Hi Aaron,
http://helpcenter.graphisoft.com/guides/archicad-18-int-reference-guide/configuration/start-archicad...
To enable it again, use the File > New & Reset All command.
Have to press the Alt/Opt key for File > New & Reset All to show up.
Seems kind of brute force... would be nice to have a simple WE checkbox for it.
If you want to get the dialog back without changing anything else that a New & Reset does (I'm not really sure of how many things that changes) ... there is a plist item you can change to 'YES' if you want to get down and dirty... see attached. For Windows folks, I assume there is a similar Registry setting...
The plist is in ~/Library/Preferences ... screenshot is the Xcode editor.
Here's a text editor view of the plist XML file, search for the word 'Startup'. Yours will show "<false/> where my screenshot shows <true/>. Just change it/save.
David Maudlin
Aaron:
Go to your Work Environment and add the command Enable All Informational Messages..., this will bring back all the dialog boxes where you checked the "Do not show this again" box.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
