Is there a setting to restore the Open File StartUp dialog box? I've dialled this by accident and now have to start ArchiCAD and let it open a new file before I can access this dialog.
I scoured the preferences for a button, but haven't found anything that is relevant. Thanks!
Think Like a Spec Writer MacBook M4Pro AC4.55 through 29 / USA AC29.0.1 USA Rhino 8.24 Mac MacOS Tahoe 26.0.1
If you want to get the dialog back without changing anything else that a New & Reset does (I'm not really sure of how many things that changes) ... there is a plist item you can change to 'YES' if you want to get down and dirty... see attached. For Windows folks, I assume there is a similar Registry setting...
The plist is in ~/Library/Preferences ... screenshot is the Xcode editor.
Here's a text editor view of the plist XML file, search for the word 'Startup'. Yours will show "<false/> where my screenshot shows <true/>. Just change it/save.
Go to your Work Environment and add the command Enable All Informational Messages..., this will bring back all the dialog boxes where you checked the "Do not show this again" box.
David
David Maudlin / Architect www.davidmaudlin.com Digital Architecture AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
