Roof accessories - cannot find the Archicad 28 folder in Graphisoft folder
Kiarara
Hi!
I have been trying to use the roof accessory tool, but after watching multiple YouTube videos, I still could not manage. I installed the goodies. Now I do have a roof accessory option, but the library is empty. And when I try to add it from the folder, then there is no such folder as "Archicad 28" as the forums and videos suggest.
What should I do?
MitchD
"C:\Program Files\Graphisoft\Archicad 28\Accessories Library" would be the folder you're looking for.
it appears you're in "C:\Users\<USERNAME>\Graphisoft"
ArchiCAD 28 /// Win 11 Pro - Ultra 7 155H - 32GB RAM - RTX 4060 8GB /// Win 11 Pro - i7 12700 - 64GB RAM - RTX 3070 Ti 8GB
4 REPLIES 4
MitchD
And don't just load the folder.
You must load the 'Accessories Library.libpack' file (library pack).
Thank you so much!
Thank you, Barry!
Setup info provided by author
