Simple laptop vs. Powerful laptop?
Hi, all.
For Archicad 16, does it make much difference if your laptop has a lower gaming video card, vs. a higher one?
For example, a Radeon 6520G vs. a GTX 660m...
(I know I read somewhere that lower onboard cards, like the Intel HD 3000, aren't recommended.)
Thanks!
3 Replies 3
Or let me just ask this: will ANY new laptop run Archicad 16 just fine, if you aren't working on massive projects?
Edit: whoa, my replies appear at the TOP of thread. Never seen that before in a "normal" forum, and I'm member on over 100 of them.
Erich
This is a preference you can set. Go to your profile.
As for the lap top, it sounds as though you are using a windows based machine so there are a lot of variables but generally, ArchiCAD will benefit from a reasonable video card and a lot of RAM. If you do a search there was a video that Graphisoft put out a year or two ago that went through the basics. While a little old the same concepts apply.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
Thanks for the help.
Actually, I already looked over the official video cards article, but came away still not understanding if the average user would do fine or not using a cheaper laptop from this year.
