I'm having the same problem with the stair steps not showing on the layout, the stringers are still visible though. In my case it is related to spiral stairs, straight stairs are fully visible. It's not related to the view settings (I right click the faulty view on the layout and select "open source view" and the stairs are fully visible then)
I have tried everything, changing the renovation status of the stairs in different orders (change status to demolish-change status back to existing-update view on layout / change status-update view on layout-change status back-update view on layout / change status from existing to new-update view / etc).
I've tried to reset the renovation status of everything in the model. I've tried to use the pipette to redraw the buggy stair as a straight stair to no effect. I've checked some stair copies that I had saved in the dummy layer that I havent edited since the stair type last was functioning properly but those also are missing their steps.
I'm using AC23 v5005 SWE FULL
Any thoughts or more specific instructions to apply the workaround?
Thanks in advance
Edit:
I've tried changing the finish type from Step (built in) to Step 23, which I use in my straight stairs but that didn't change its representation on the layout view. I tried to change the structure from stringers (which are visible) to monolithic but then the entire stair disappears in the layout.
Edit2:
It's only the stringers that remain visible, the walking line is missing as well. I'm not sure about the numberings as they should not be visible as per the MVO.
	AC23 V5005 SWE FULL
Work laptop: Intel Core i7-6820HQ @ 2,7 GHz, 32 GB RAM, Nvidia Quadro M1000M 2GB GDDR5 (+16 GB RAM shared from system), Win 10 Enterprise
