Stairs not showing on the Layout. Going mental.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2019-04-11 02:40 PM
Solved! Go to Solution.
- Labels:
Performance
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-06-10 10:08 AM
Have a great day!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-11-30 08:55 PM
Thanks Minh, that did the trick. Weird that it wouldn't work without going through the exercise of adjusting the Show on Renovation Filter setting.
Thanks,
Mark Benner
AC 23
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-03-03 10:09 AM
I am facing a similar problem. My stairs are not showing properly on any floor plan. Either on a layout, saved view, or project view. It shows perfectly fine in 3D and section views, just not on plan views. I checked every possible view/layer/override settings but nothing makes the stair visible. It only shows a couple of nods indicating there is a missing library element, but my library settings seem fine. The only parts missing there are the MEP elements such as pipelines, but no stair elements.
Furthermore, I tried the renovation filter workaround but... Archicad consistently crashes (bug report) when I try to alter any renovation filter status of the said stairs.
I am desperate for a fix because I now can't finish my work on time.
Thanks in advance.
Sincerely,
Leon K
Archicad 25
Macbook Pro 2018
2,2 Ghz 6-Core Intel Core i7
16GB 2400MHz DDR4
Radeon Pro 555x 4 GB
macOS Monetery Version 12.2.1
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-03-03 10:40 AM - edited 2022-03-03 10:40 AM
What happens if you create a new stair?
If the same, try a new stair using a favourite - this will reset all the default settings.
For some reason it looks like the 2D display of the treads and grid is not valid.
Hard to say what it is without seeing the actual object settings - probably to many to try to post screen shots.
Maybe select the stair and save selection as a module (MOD) file.
Then you can zip the file and attach it to a reply.
Then we can open it and maybe spot what the problem is.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-03-03 11:14 AM
Hi Barry,
Thank you for your quick response. I tried placing a stair using a favorite, and this does show on the floor plan. However, when I try to alter the settings to match my design, Archicad crashes again.
Also, in the stair settings dialog there appears to be a bug. I embedded an image showing the CUT SURFACES tab floating on top of the other component settings meaning I can't adjust half of the settings.
I also embedded the zipped module file of the corrupt stairs.
Thanks for your assistance.
Sincerely,
Leon
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-03-03 01:04 PM
Well that didn't work as I thought it might.
Stair was fine for me, so I can't tell what is wrong at your end.
Except make sure that only the Archicad 25 library is loaded and not other versions as well.
When you look at the tread settings, what tread is being used for you?
As for the doubling up of the settings dialogue, are your video drivers up to date?
Does stretching the dialogue or closing some of the other sections in the dialogue help?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-03-03 02:09 PM
Tread 25 just as yours is showing. I can't even stretch the maximum going depth of the treads without Archicad crashing. Absolutely horrendous.
Video drivers etcetera all up to date. Updatet everything yesterday and my fear is dat not every component of the software is as compatible with the newest version of macOS as it should. Stretching/closing/opening other sections has no effect.
Leon
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-03-03 04:45 PM
This is strange and I am not sure what is going on.
Maybe you could contact your local Archicad support and allow them access to your machine so they can have a look?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-03-03 05:28 PM
Thank you for your time Barry. I will try to consult them.
Sincerely,
Leon
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-01-09 09:28 PM
Same issue on every one of my projects. (Arch 25 running on OS Monterey). This fixed it on one of the projects. Have not tired the others yet, but assume it will work. Thanks!
Denver, Colorado
- « Previous
- Next »
- « Previous
- Next »
