Installation & update
THE BEST CONFIG FOR ARCHICAD 11
i need some help to choose the best pc configuration for using Archicad 11.
Can you help me ?
Thankyou a lot!
11 REPLIES 11
Thomas Holm
zucoc wrote:
f you ghost from project map instead you'll see big improvement in speed even if the project is very complex.
This of course means the trace will show the same layer combo as the main.
I guess using view map = different layer combos will mean a speed penalty still when AC goes multithreaded.
As a 32-bit application, ArchiCAD can use a maximum of 4GB of RAM. But, some operating systems put a limit on this: Windows XP 32-bit and Vista 32-bit imposes a limit of 2GB.
