Installation & update
Text I can see on a Publisher View Set (PDF) is not showing on the PDF print.
4hotshoes
When I select the publisher set I want, to make into a PDF, I can see the text. But when I actually make the PDF, the text disappears. What might cause this? See the attached images
Todd Oeftger
AC27 Mac MacBook Pro 15", 2019, 2.3 GHz i9, 32GB, Radeon Pro 560X 4GB, 500GB SSD, 32" Samsung Display (2560x1440)
1 REPLY 1
4hotshoes
I may have identified/solved the problem. I had my Archicad file open all night. When I restarted Archicad, the PDF would show the printed version correctly. I may have "too-old" hardware for this version of AC22. I have found that restarting AC alleviates many odd problems. Graphisoft has told me before that they cannot guarantee AC will work predictably well on a 2012 machine.
Todd Oeftger
