2008-09-05 03:23 AM
2008-09-09 03:33 PM
2008-09-09 03:39 PM
2008-09-09 05:52 PM
Djordje wrote:If I understood correctly, Mac OS is not hard coded to specific addresses, Xp is, so Macs do not have to reserve the Memory space and it is open to any application.
If it is Intel x86 problem, how come it does not affect the Macs?
2008-09-09 06:17 PM
2008-09-19 12:56 AM
Unless you're running Vista x64 ... you simply can't use more than 4GB of RAM on a Windows PCWhich would lead one(or me at least) to the obvious conclusion that if you want to use more than 4Gb of RAM, then use Vista x64. I can't think of any good reason why you wouldn't use Vista x64 either. Sure there are problems with drivers for some older hardware, but have you tried plugging that same hardware into an OSX box?
2008-09-19 01:09 AM
2008-09-19 01:21 AM
2008-09-19 11:46 AM
March, wrote:When the time for the next hardware change comes, the option evaluated will be ... not that I am green and small
So Djordje are you finally going to make a move from the 'Dark Side'?
2008-09-19 06:32 PM
