Why can't you adjust the door sizes in the curtain wall tool. Are you just supposed to set the panels to have the size you want in the frame and then add more frames?
You can't use the shift lock in the curtain wall tool to get a distance off a frame them move it. You can't set the origin point either.
This tool seemed good until the need for a door to be a certain size or adjusting the scheme lines.
Archicad 25 (5005), Windows 11, AMD RYZEN 7 3900 (64 GB RAM)
