Tiger 10.4 Problem Default Open Path in ArchiCAD
Just wondering if any one else is having a problem with the default open/save Path in Archicad-9 on tiger OSX 10.4 as shown in this Pic. The Tiger pic also has 2 System drive icons one is sort of greyed out but not selectable It only occurs in Archicad & Plotmaker although its a different location.
Martin
11 REPLIES 11
Aussie John
Martin I notice you appear have non default icons in the side bar of the finder winder. Its not some sort of hack is it?
Cheers John
[/size]
After this topic became inaccessible & under investigation I posted a new topic to reply i think that one is back up also after suffering the same inaccessibility.
< http://archicad-talk.graphisoft.com/viewtopic.php?t=7270>
