Ted Taylor
Tiger flashing in OpenGl
Since installing Tiger, the following has started when OpenGL is the rendering engine. No problem with internal 3d engine.
When selecting something in 3d window , the window flashes totally white twice. When moving viewpoint it only flashes once. Tried it with and with out hardware acceleration. Tis a bit annoying. Any body else running into this?
Ted Taylor
Atlanta, GA , USA
iMac (Retina 5K, 27", Late 2015)
3.3 GHz Intel Core i5 32GB
AMD Radeon R9 M395 2GB
OS10.14.2,
Latest Archicad 22
14 Replies 14
rm
Was happening here too. Except it started after 9.0 was installed for me. I'm running OS 10.3.8.
However, I updated to build 2018 and it has stopped. Are you on the latest build?
Be warned, if you update to the latest build from the first revision ( cant remember the number ) it will probably screw up AC. I had that problem. For some reason GS told me to reinstall AC 9.0 from the original disk, then update to 2018 build.
Good luck
Robert Mariani
MARIANI design studio, PLLC
Architecture / Architectural Photography
www.robertmariani.com
Mac OSX 13.1
AC 24 / 25 / 26
Ted Taylor
I'm running build 2018 also. Must be some particularity in my setup.
Ted Taylor
Atlanta, GA , USA
OS10.14.2,
Latest Archicad 22
I have the same problem. I haven't done any investigations yet into possible fixes. I see we both have the ATI Radeon card. Maybe a new driver? I'll let you know if I find something that works.
Steve Campbell
ArchiCAD 9.0 PowerMac G5 Dual 2Ghz with ATI Radeon 9600
__archiben
no problem here: Mac Powerbook G4, ATI mobility card, tiger and AC9 2018 . . .
must be that super-duper new video card they're putting in the new G5's to drive the double cinema displays?
~/archiben
b e n _ f r o s t
I don't know if this is related:
http://www.macosrumors.com/20050506.php
Ted Taylor
I downloaded and installed new driver for 10.4, apparently I now have the ability to rotate my monitor 90 degrees but unfortunately it is still flashing. I just about have the timing of my eye blinks down to matching the flash, so it is not nearly as apparent.
Ted, thanks for the link to macosrumour. That may explain it.
Ted Taylor
Atlanta, GA , USA
OS10.14.2,
Latest Archicad 22
__archiben
more on this - it is a bug: i opened another project and saw what you were talking about. i've tracked it down to the background selection. whenever i'm using 'As In Photorendering Settings' as the 3D window background, and the photorendering settings are using lightworks images (scaled in my case) you get the flashing.
anybody else verify before i send it off to the tech guys?
cheers
~/archiben
b e n _ f r o s t
Aussie John
Macosrumors is a very unreliable "rumour" site. They seem to make things up
Cheers John
[/size]
Gorazd
Hi guys. We have here very mixed environment. One Mac mini, PC with XP home and HP notebook with XP pro. They all have AC 9 installed, and flashing of the monitor appears on all machines. It doesn't flash all the time. In some project it does in others i doesn't. It drives us nuts, and we can not figure it out. Also in the same project, in the mornig it flashes, after lunch it doesn't. Any help?
Gorazd Rajh
From AC 6.5 onward, i9-14900HX, 32 GB RAM, RTX 4060, Win 11
